Thread: Tire choices?
_dV
12.17.2009, 09:39 AM
Just ran the stock tires initially. Was fun for a while but the handling was a bit wild and inconsistent with the tires ballooning. Offroad grip wasn't great.
After reading some forums i went to the Proline Badlands(MT size) on 17mm 1/2 offset Maximizer beadlocks. These tires have a phenomenal amount of grip offroad. Some of the hill climbs i've done with them have really suprised me. Looks wise the tread pattern suits well but they appear too small on the truck for my taste.
I put 3 1/8 inch holes in each Badlands tire and strapped the inside with Scotch\3M Strapping tape. It lasted for about 6 ~45min runs on gravel\dirt before the rears let go. The outside of the foam was fairly dusty when i opened them up.
The Maximizers look great. They have been useful for experimenting with tires\strapping. The Badlands are a very tight fit on them though and i stripped a couple of screws getting the four tires on. It does get easier and quicker though once you have taken them off\on a few times. On the last two runs the bead on one tire pulled out just a small bit from the wheel and i had to loosen and refit it.
I am about to try HPI GT S tires on the Maximizers. They look awesome. I've ordered the firm HPI foam (4667) for them. The stock foam seems a bit plush. The GT tires aren't as tight a fit as the Badlands, much easier to get on. Hopefully this doesn't mean the bead will pull out easier. I'm going to find some gaffa type tape to try with these in the hope that the dust affects it less. It should be wider too so probably 2 strips instead of 3, less joins for the dust to get into.
Wheel\tire combo weights:
Stock - 299 gm
Badlands\Maximizer - 325 gm
GT S\Maximizer - 386 gm (bit heavy, if i like the tires i'm thinking i will glue them to some dyed black JConcepts Rulux wheels)
There doesnt seem to be an ideal bashing tyre atm suited to 1/8 scale brushless trucks. I'd like to see something like a larger diameter Badlands (with some sidewall support) with slighter wider tread width that was belted to fit standard MT size wheels. Or may a same profile Badlands but larger inner diameter to suit the larger diameter low profile type wheels (again belted). A harder compond tire would also be interesting to try. Moulded closed cell inner foams would be great too.
Stock Flux, HPI GT S On Maximizer beadlocks, Proline Badlands on Maximizer beadlocks
Smaller diameter and width of the Badlands
Remains of the strapping tape and dusty foam
Remains of tape still stuck to the tire. It appears as though the dust stopped the adhesion working
How the tape looked before
Test fitting the new wheel\tire combo on the truck
