12.21.2009, 12:32 AM
That second link would be a better choice as the first one does not specify a dropout voltage. At any rate, care must be taken to not discharge the lipo/liFe too low. You would need some kind of voltage display hooked up between the battery and regulator so you know what the true battery voltage is, not the voltage at the output.
