sikeston34m
sikeston34m's Avatar
12.27.2009, 05:52 PM
Originally Posted by turbo4 View Post
I'm using thunder power pro packs (30c). These are new packs. If the ESC is looking at total voltage then how is it cutting of at xx volts per cell? I have mine set at 3.2v per cell, however I had one cell get to 3.08. I did run the truck until the cutoff. I did not notice a stutter, but It would stop altogether if I gave it full throttle. Every time I go to charge the packs one pack is always less voltage than the other. I have not kept track of if it is the same pack each time, I just figured that one side was driving the servos or something.
Thunder Power Packs have a very good reputation.
The ESC calculates LVC by doing a little math. 3.2 volt per cell cutoff X no of cells. In your case 19.2 volts.
What do you balance your packs with? Balancing is very important.
If your packs are out of balance, you will see a low cell like that.
