DCastaneda
Speed Addict
DCastaneda's Avatar
12.28.2009, 09:18 PM
I thought it was pretty well known the packs on the left side will drain faster in the northern hemisphere, right side for the south.
Man you guys need to brush up.....
+1
Could be since that one pack has a weak cell, so once balanced, the pack with the weak cell will have say 4.05volts per cell whereas the other pack is very well matched and its cells all balance out to 4.20volts. This would cause the discrepancy seen in your packs. best bet is to balancer charge, allow blinky to finish, and then balance charge again so the voltage difference is minimized.
  Send a message via AIM to DCastaneda
