hlb14
12.31.2009, 09:08 PM
That's not even 20k rpm on 3s. If you gear high enough to have decent speed, you might get cogging on startup as the ESC tries to find rotor position. A sensored system would tolerate this better. I would get a motor with a kv of ~3000 (for 3s) or 4500 (for 2s). Low kv isn't always best - it's about matching the kv with the voltage.
ok, thanks, sometimes i get these wild thoughts in my head and need you guys to set me back on the right track, i have decided to stick with lipo instead of jumping to life... thanks again brian
