Originally Posted by anthony213
need a good charger , 1 that charges up to 6000 mah and does 2c charges . what do you guys recomend ?
12 amps is what you spec. If you'll put up with 10 amps (there's many chargers with a 10 amp limit) then for 2S you may like the 989 MRC superbrain. For 3S you might like the Checkpoint TC 1030. There are also many Chinese chargers that will do 2-6S at 10 amps. (i-chargers are one)
