Originally Posted by SpEEdyBL
If you didn't read my other post, i run a Zippy 40c 4s 3000 mAh in my buggy and and makes 10 min. mains on an indoor clay track with ease. Setup is 8ight/tekin 1900. Temps are motor: 110-120F, battery: 90-100F
Problem is 4s with 1512/2.5 is not fast enough. My spur is 46/16(max pinion due to the meshing.
Either I change motor or change batt.
My truggy is using 6s. I think to run both cars on 6s is cost saving n both are almost the same setting.
Just thinking of 2650 or 3000mah becoz of space in the buggy.
