What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.01.2010, 10:57 PM
If you can get a new balance plug for 4s (5 wires) it would be easier IMO. With the two separate plugs there will be a common wire between the two. If you use two separate balancers this isn't an issue. To use one balancer you would at least need to make an adapter.
