01.08.2010, 04:07 PM
Well the body is heavy, and you need to add a fiar amount of body reinforcement if you want it to last. I plan to bend up a cage, so that will add some weight. Plus wheels and tires, I will use std MT wheels and section up some moad xl tires to get the correct 5t look.
Also, whenever you lengthen the WB you get addl load on the motor, as the vehicle does not want to wheely as easily. I figure that my running weight will get close to 18lbs, so a 1527 should do.
