Thread: LIPO charging
hoober
01.09.2010, 02:39 PM
If I understand , you want to parallel the balance connnection between packs while they charge thru the main lead like normal.
I could try to parallel a pair of packs on my 977 (without balancer because it won't matter)
Basically it is like hooking both outputs together and I'm not sure if it'll cause problems if the packs contain the same number of cells.
OR did you want to series connect the balancer? If so that will not work out. The best thing to do might be to balance them "on the side" so to speak and just balance one at a time while charging them both at same time.
