02.05.2006, 12:30 AM
Originally Posted by squeeforever
im not sure what they mean by power adapter but all the wanderers use 5.5mm connectors that are pre-soldered on them.
Thanks squee.
Well, if the EMF braking feature does cause voltage spikes into the batteries (and therefore into the BEC), I suppose you could use something like a 36v Zener diode (at least 5w) to clamp the voltage. That should keep the spikes within a BEC's safe input range.
Has anyone had "issues" with their BEC during or after heavy braking? Something like unexplained radio signal loss for a few seconds, glitching, or other odd anomalies?
