01.12.2010, 02:36 AM
If you have the newer firmware, I would set it to auto-lipo and then the cutoff to 3.2v/cell. That way, it is ready for anything from 2s to 4s. Some setups I have I run 4s and 5s, and this mode makes it easy to switch without having to change settings at all.
Oh, and I assume you are running an external BEC with the internal one disabled right? If running over 2s, I would definitely do that.
