01.12.2010, 02:08 PM
Originally Posted by redshift
Every metal is porous, but only iron or certain iron-containing alloys will 'rust'.
Aluminum oxidizes, which is a protective layer actually. You can polish, sand it etc. and the oxide will immediately re-form.
So you can sort-of call oxidation "aluminum's rust" but it's only billionths of an inch thick, and will not corrode like iron will. It does corrode, but in a normal environment this will take decades or even centuries...
I sit corrected!
