Little more progress. Brazed the front and rear of the frame rails together.
I think this is about where the front of the body would rest on the frame. Some is showing but there is normally a bumper there.
Set the interior back in to see how that is going to work out. It's surprisingly close actually. I'm going to have to cheat the floor boards a little and make room for the frame rails.
I was going to have the transmission mocked up in place with the motor mounted but found out that the 1717 uses 4mm hardware and not the normal 3mm. So it won't mount on the RCM motor mount without modification
Radius arms are ready
