Superemaxx89
02.05.2006, 02:21 PM
whats an lvc?
What are taps and balancers?
I will not be upgrading my voltage in the future, 22.2 volts is plenty! So should I go with a 20120 or 12020?
Will it be any "safer" to just go with a 20150, or is there absolutly no chance a 10xl will get to that amperage?
What speeds will I be looking at? Should I move down to a 9xl for more speed, or is a 10xl good?
Anyone have a KV chart for wanderer motors?
EDIT: I found a hacker B50 chart, which should be the same as the wanderer (+- a few kv, but whatever). My old setup, 8xl on 16 (19.2v) cells got 37881.6 rpm and my new setup, 22.2v on 10xl will only get 35031.6 rpms. So it will be considerably slower, but will I be able to make up the difference in pinion size (say 24 tooth pinion, 51 tooth spur). Or should I go with the 9xl, which will bring me to 38916.6? Should I email rcmonster on this? Thanks.
