Originally Posted by bigsteel
would there be a big problem with running racing fuel in a baja? i've done quite a bit and i was going to bump up compression with a thinner head gasket but i figured id try it the easy way with higher octane fuel.i've got a new engine on the way already so i dont mind experimenting on the stocker.--josh
No issues running race fuel in a Baja, I run Sunoco 260GTX which is an unleaded race fuel. You can run leaded race fuels as well and should not have a problem.
