More info
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
More info - 01.19.2010, 07:19 PM
Ok, well that is awesome that it will work. I just figured that the bottom plate is machined a little and I will never need it.
JoFreak - The custom drive shaft thing would be nice.
I am sure that there will be mroe info on this once most of us has them in hand. I would believe that you may be able to sell the bottom plate if you will not use it. Shafts would be nice, but it took long enough(two years) just to get these kits into production with everything else that MonsterMike has on his plate. Besides we already have resources for shafts through RCalloys.com if you need a special shaft made for your particular setup. If you are lucky enough to have a vehicle that this thing bolts right up to like the original tranny the shafts you have already will work fine.
SUPERMAXX YOUR LIFE.
