Hobby City "EC5" 5mm bullet plugs
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
Hobby City "EC5" 5mm bullet plugs - 01.19.2010, 10:25 PM
Yup, 5mm. They are deisel big, "should" be better than the Deans even though I've never had a problem w/them. I wanted them for Hopefully better effciency. Gonna try them on one of my heavier 5s set ups and see how they work.
This evening I got a few solderd on, I must say, they are very robust plugs !
My only complant is if you fill the bullet a little much it'll over flow onto the out side of the bullet and it must be removed befor installing into plug, It's a tight fit without the solder on the exterior. The plugs go together smoothly and tight, there grip they have on each other is authoritive and requires some "umph" to seperate. Now the question is how will they last with repeated installs and removals, time will tell. At $1.29 for the male & female plugs it's a bargin in my book.
Pictured next to a full size servo for scale
ID:	8382   Click image for larger version
