Well this is just a teaser because I ran out of oxygen for the torch
Frame mount attached for the beam.
Radius arm mount. Thinking about maybe attaching this on the side of the frame rail intsead so it's not hanging down to catch on things?
Definitely needs fender work now
Some drop out action
Going to have to tweak the radius arms some. They are causing the beam to have the wrong caster. If I just shorten the top rod end on the radius arm it should bring back the caster correctly.
