Thread: MMP Start Power
Pdelcast
Pdelcast's Avatar
01.21.2010, 10:19 PM
Originally Posted by Lauri View Post
Ok. I will then try to figure out what was the case. Patrick, could you only state some RPM range the Start Power is active? For an example up to 0 to 1000rpm?
Well, that has a complex answer -- it's related to the Kv of the motor -- high RPM, low turn count motors will be in "start" mode longer than low RPM high turn motors ... But in any case, the controller will drop out of "start power" controlled mode (and ramp current faster) in under a few hundred RPM worst-case. In some cases (like on a 17.5 turn motor) the controller is out of controlled start power at around 100RPM.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
