Thread: MMP Start Power
01.23.2010, 07:10 PM
I have a feeling your battery was not fully charged and that is why you only got 1500mah out of it. Unless your setup was actually overdrawing the battery there is no way to "pull the voltage out" without discharging the capacity. If your lipo is still working then I can only think the charge prior to running with hight setting ended too early.
We need specifics on battery brand and what charger you use...
