Thread: Tire choices?
Weights
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Weights - 01.25.2010, 10:00 AM
I just use modeling weights with double sticky tape, and then once I have a full set of wheels properly balanced I use the hot glue gun to make sure they will not come undone. Yea they do run allot smoother balanced for sure at higher speeds. Once you do the first set the process becomes fairly easy to do.
SUPERMAXX YOUR LIFE.
