Sounds like
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Sounds like - 01.25.2010, 11:48 PM
It sounds like you have a compatability problem with your memory. That is what happens when you try to go budgit on memory. One thing that I have learned is that if you really want to build a good computer you need to invest for the best and get it over with. The problems it will save you in the long run are worth it. Never go for cheap memory.
SUPERMAXX YOUR LIFE.
