J57ltr
01.26.2010, 12:19 AM
I could but it would be a pain unless I am overlooking something.. I dont want to do dogbones or anything... .
I could do just a center diff mounted on the rear with mechanical brakes... then I need to worry about gear reduction etc.
If you look at the rear of the Ripsaw you can see that there is a Ford 9" or Dana rearend mounted up high that actually drives the rearmost wheels. You could do a disc brake on each end and use a single servo to apply either brake for skid steer.
Something like one of these:
http://www.rc4wdstore.com/2/index.php?cPath=19
Jeff
