01.28.2010, 03:44 PM
If you are playing in mud, bashing with badlands... no need to put holes in anything in this case. Seal them up real good to keep the water and mud out. If you ever have an issue with the tires being too bouncy or staying flat/expanded due to heat build up or cent. forces, etc... THEN you can put holes in them.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
