JThiessen
JThiessen's Avatar
01.30.2010, 02:03 PM
Freeze - clean it up man.
The towers did not collapse due to the impact of the planes. The superheated fire melted the structural steel support beams (which ended up exposed due to the impact's). This fire was "superheated" due to the large amount of jet fuel (remember, the planes had basically just taken off, so they were full of fuel. Once those structural beams melted, the weight of 40+ storied of building above the impact zone combined with a classis case of gravity (not a conspiracy - its real) and you get what looked like a stand building demo.
If you cant understand how a fire can do this - go get a torch set and play with some steel for a bit. As for "lack of Aircraft parts" - study the melting points of steel as opposed to the materials used in airplanes.
Pyroclastic cloud - DUH! That's exactly the effect you'd get with a fire like they had and the forces involved with a collapse of that magnitude. Under that kind of weight and pressure, the steel beams were heating to incredible temperatures as they came down. Try bending a paper clip until it breaks - feel that small warm spot right where it breaks? Same thing except on a magnitude that most people really cant fathom.
#7 was hit by debris and damaged enough that it was cheaper to take it down than it was to rebuild it.
et engines look very similar inside structurally inside... and btw, I bet they didn't tell you that the engine debris was WAY to small to be from a 757.
The types of aircraft reported were initially wrong - but the reports by late in the day got them correct. How do I know - I've spent the last 20 years designing and building those exact airplanes. I can tell a 757 from a 767. And by the way, please tell me the size difference in the engines on a 757 vs a 767. Hint - this is a trick question.....
There is NOTHING about the destruction that defies any engineering logic. Dont believe me - go get a degree in some form of structural engineering, or 10+ years of experience in some form of industry that deals with structural materials, THEN come back with your argument. Now at the ripe old age of 19, you need to take some of your own advice, and quit looking for ways to connect your percieved conspiracy and random events. Its been my experience that people who want to connect events to support a belief can and will find ways to do this. You shot down Texas belief in God (wrongly), and yet you'd probably be the first to tell him that his logic in connecting Biblical profecy (i know I spelled that wrong) with current events is completely off base and without logic. People of all beliefs do this same thing every day - can they all be wrong at the same time???
