01.31.2010, 11:44 PM
Before you get all wound up, check your esc to motor connections. If you are using bullet connectors, especially 4mm ones, ditch them and direct solder the wires together. I have had alot of issues with connectors between the escs and motors. Only decent connectors I have used are the giant castle creations ones.
Bar that you most likely have the lipo setting wrong. My memory is a bit rusty but there are 3 lipo settings, and I used medium and never had issues. The dynamic startup did help on a higher setting, but only with outrunners that had really high gearing on them. I had a few 80 escs, a couple of 125b and a few 65 amp escs too. And a 33 amp esc. All worked great, but I did smoke a few with extreme setups.
