lutach
lutach's Avatar
02.02.2010, 10:23 AM
Huh, I wonder how much the 30Kw unit costs? That looks superb for a high performance electric hybrid, very efficient... should be able to maintain at least 175mpg at all times, over the range of the car, accounting for the initial all electric range.(depends on size of battery)
So do you have access to this type of gen. set then? at what cost?
I know you can make a crude turbine engine from a traditional turbo charger, not near as good, but it works non the less. I wonder if it could be fined tuned to power a small vehicle such as a hybrid motor bike?
Give Capstone a call, I posted the link above ( http://microturbine.com or http://capstoneturbine.com/). There's no secret with this one as it's a public company. The info I sent you is a different story. I don't know the cost, but it'll be worth every penny. Also, your 175mpg calculation is very conservative. I don't think the little home brewed turbine will have enough torque to get the 30Kw generator going. I might be wrong though, don't really know much about turbines. Capstone also has a 65Kw and a 200Kw unit. Best thing about them is the fact you can use 6 types of fuel, like the unit I sent you info on. Here are 2 distributors in Canada: www.onpower.com (Eastern Canada) and www.tarponenergy.com (Western Canada).
