crazyjr
crazyjr's Avatar
02.02.2010, 07:12 PM
Yep -- we are going to try to do it so that it could be just a software update, but at this time we aren't sure if we need to do any hardware changes.
The real issue is braking energy. If the Phx-ICE design is tough enough for braking energies (it wasn't designed to be a car controller!) then we won't need to update hardware. If we run into braking issues, we may have to tweak the design a bit, or add some external hardware.
If it is just a software update, Can it be used on any ice esc? or, will it be limited to the 200 amp and or the 160 amp? I like the design and would like to run them in smaller scales (1/10 to 1/16) thanks.
Edit: I got one problem, i see two different sets if ice hv esc's
These: http://www.castlecreations.com/produ...oenix_ice.html
and these:http://www.castlecreations.com/produ...ix_ice_hv.html
Which one are we talking about?
