Nard Cox
n00b
02.07.2010, 06:09 AM
Hi there,
1. (dimensions) Dimensions depend on the spur/pinion you are running. I'm running stock spur and pinion and the with is about 37mm, will be about 2 to 3mm longer if you will use the supplied spacers on the left TVP to widen it a bit more. The length is about 160 or more I guess, The hight is about 60mm but pretty much unlimited. What battery with what dimensions are you trying to fit?
2. (base ESC) No idea, will measure that when I have time.
3. (front tray area) No idea, but will check that asap.
4. (spur gear cover) If you can mod a little I'm sure it can, but I don't think it fits without any mods, but again will have to check this to be sure.
5. No. But today the whether is good so I should be getting some air time today. It's 11:08 here now and will go bashing (hopefully) @ 12:00. Will bring my camera for some footage.
I'm in bed right now and will try to give an answer to your questions asap!!
