Nard Cox
n00b
02.09.2010, 06:37 AM
Originally Posted by _dV View Post
What is the distance from the base of the ESC to the rear shock tower? Wondering if it would get hit like the stock Flux setup.
What are the dimensions of the front tray area? Wondering if the ESC could be moved up there and if that would create more battery tray area.
73mm / 2.87'' wide and 80mm 3.15'' long
But I doubt it would create more space because the motor is sticking out more then my battery tray (again with stock spur and pinion). For the weight distribution it is not needed and as you can see you would need some modding to get it to fit up front.
Can the Flux spur gear gear cover be fitted?
Not without mods. You could attach it to the handlebar somehow.
Also, any jumping yet? How does it fly?
Well lots last sunday and it jumped really well. I will upload a 'raw' video today of some jumps (hopefully).
Sorry that it took this long.
EDIT: movie is online. Not the best because of the angle but it shows a bit.
[YOUTUBE]f01fNwZCBf8[/YOUTUBE]
