joostin420
02.08.2006, 03:51 PM
MaxxFusion - are you running a 5300? i am running a 5300 on 7cells.
the bar for the body posts is painted silver, the body posts in the front are aluminum - not sure where they came from though. the top plate is silver carbon fiber that i designed and cut.
i took it to the track around christmas time messed up my steering servo i think. i also damaged the wheels on the wheelie bar so they need to be replaced :005:
i decided since the M2k's sucked so bad on packed dirt i was going to go with a pin tire, but the 2.2 pins are all so small in diameter compared to the M2k's.
so i got some stampede-to-maxx adapters, some Proline maxx offset dish wheels, panther kamodo pin tires. the tires are about 1/8" taller so they are perfect because i will be able to keep the ride height.
justin
