02.14.2010, 01:58 AM
You don't have the throttle servo connector in the receiver backwards do you? Make sure throttle trim is at 0 and the travel is 100% (or more) in both directions. If you still can't calibrate the radio to the ESC, try flashing an older firmware and then the new one again. I had a MMPro that was having trouble calibrating as well a while back and this seemed to help. Dunno if it was a coincidence though...
