02.14.2010, 03:41 PM
Originally Posted by fsracer View Post
That motor is only rated for 4s lipo, are you guys doing anything to get it to work with
5s.
Sounds like they are using 5s lipos to get it to operate properly on 5s....
Max neu motor speed for a 15 series is 60k rpm. Seeing that the cc motors are based off the 15 series I would say the spec applies. The MMM can handle 6s lipo max so I see no reason not to run the 2650 on 5s. Good for speed runs, just watch gearing and temps. I would not try to run a lst on 5s geared for 50 with this, but in an 1/8 buggy/onroad it should be fine. Tire weight is much lower.
