Finnster
KillaHurtz
Finnster's Avatar
02.15.2010, 01:11 PM
Looks like a nice mount. Got some questions tho for Mike:
*What is the Max spur size? Looks like Chris posted a 48T is the limit.
*Is there a way to fit a bigger spur, say the 52T for the Slipperential?
*Will the mount accomodate M4 screws for a 1521?
Basically I would like to run one of these in my savage, but w/o a tranny, gearing gets very tricky. To maintain my current gear ratio, I would have to switch to the HPI bulletproof diffs (29/9) from the Cens (26/9), use the 52T spur of the slipdiff, and then still use a 10T pinion on the motor.
Even that is about 10% higher than my current GR.
I would use a FLM savage skid plate and braces to mount the diff. I can work out cutting a hole for the spur on bottom, but not sure what to do w/ the top brace.
Thanks
