02.15.2010, 06:28 PM
The MMpro would likely handle the motor fine since it is geared for ~30mph tops, but as said, the BEC might be the limiting factor. I personally would go the safer route and opt for the Tekin; not only will it handle higher gearing better, the BEC is a bit more robust.
