02.09.2006, 07:54 AM
It was fairly easy. I removed the 2 long bolts holting the shocks. Then the right side rocker bolt thats bigger and goes into the frame.
The exhaust was removed, and the 3 bolts under that.
...ermm.... I think that was it... oh wait disconnected the left side push rod so I could swivel the rocker outta the way, and loosened the motor mount bracket thingies so the drive shaft could slip under them... and of course the set screw that held the center drive shaft was removed.
I couple tugs and a slight pry upwards and the whole rear assembly came off.
Removed the blue rear backer off that.. and then it was the easy stuff.. find screws and remove it till the diff was open... it was about 8 more. .. oh ya remove the other 2 drive shafts can't get the case apart without them removed.
