nitrostarter
nitrostarter's Avatar
02.17.2010, 06:27 PM
Agree, did not compute in my pathetic brain until quoted.
Edit, Pardon me for not thinking this through prior to posting.
What about a 1527/1500KV motor on say 8s with a CD, the gearing will still be ugly high for the application ?
Most definitely. 44,400 rpm's and a fast FDR sounds like a high speed running rig. The standard flux f/r diff ratio is 3.3 and the bulletproof is 3.22 so they are relatively high speed compared to Truggy(4.3).
In order to run a CD would would need a lower KV motor or big spur/little pinions, which tend to wear out faster. Even on 6s with that motor, you would need about a 15/51 pinion spur combo and still push 50+ mph.
N. Rustler conversion
