kazuaki
02.19.2010, 02:43 PM
Just out of curiosity; are you running the center diff in there? Because running a solid center with dissimilar diameter tires can place a lot of stress on the drivetrain in general. But that's probably not why the rear shaft snapped; that's probably caused by the greater traction of those paddles. CVDs would help that a lot. I've never been a fan of the smaller slider shafts; they are just too weak to handle serious power IMO.
No center diff, the thing would be useless with only rear paddles and a center diff. Can you say Front Wheel Drive? I was aware of the issues with different tire diameters, but I figured it wouldn't matter much in the soft sand. I mean worse case, the truck has to spin the fronts a bit faster, which shouldn't be too hard. You should have seen the truck after the back end broke. I tried driving it as a front wheel drive for a minute. Hilarious...
