thzero
02.19.2010, 05:04 PM
Interesting information. Only one note, the standard Savage diffs are the same ratio as standard buggy diffs. :) If you were able to swap out and use truggy diffs then you could go with the center diff but yeah without going to lower ratio diffs, I don't think you can go with a center diff.
Oh and Moabs are more like 6.9" diameter. And the XL version are 7.3" (6.9" according to tower, but Brian's speed calc has them at 7.3"). Both which are bigger than the 6.88 (by a hair) badlands for the Baja interestingly enough. Pro-Line Trenchers for the 5T are 7.55" according to Tower.
