It is 11pm but could not help it and had to start tearing it down
Start
5 minutes later thanks to Ryobi 4V LiOn screwdriver
steering post screws had so much loctite on that I stripped both of them. Oh well I don't need them :)
Alu towers are mounted.
Work left:
Dremel central CVD and wheel hex adapters pins for added security
Put all lightened parts on the drivetrain
Rebuild diffs with 15-20-8 to keep the Mspec ratio of 7-10-4 and shim the properly.
Dremel BCE chassis central diff hole a bit for slipperential to fit correctly
I am waiting for the motor mount and battery tray and lightened steering posts, but the rest of the truck will be done in day or two. I just love mugens for being so easy to work on. Almost as easy as D8.
I will keep rest of the setup according to the Mspec sheet just to see how it does.
