sikeston34m
sikeston34m's Avatar
02.19.2010, 11:55 PM
Originally Posted by ANGRY-ALIEN View Post
Well... I'm not sure the fan is problem... it does kick in at 139° internal during 'Charge mode'... and it does sound healthy... I also just remember it won't go over 5 amps too for
'Charge mode' even if I set it for 6.... Could it be the Fets? or could it be something bigger?
I'm not talking about the power supply fan. I'm talking about the fan inside the charge unit itself.
The charge unit limits it's charge amperage to the capability of the power supply. They are matched. Think of it in watts of output.
The larger the voltage of the pack, the lesser the amps that it will charge at.
I'm sure it will charge at 10 amps if you're only charging one pack, but put them both on in series, and it's going to limit you.
