Rivermaxx
02.21.2010, 11:33 AM
The 44T spur will hit the x-braces if it sits low unless the G3 chassis is a bit wider than the G1. This is the reason why I made the mounting plate. I also tried a Kyosho 46 and Ofna 48T spurs but the 44T works the best unless I use a CNC in making the mounting plate holes.
I want to say they are exact but maybe your braces are thicker than mine?? They look like they might be. The 46 tooth would fit with a little bit of clearencing but I want to see if a 44 tooth will fit before I do that.
