sikeston34m
sikeston34m's Avatar
02.22.2010, 01:09 AM
Nope not yet, I usually shut down completely from R/C come fall and then get re-inspired in late winter, such as now.
Luc, supporting the outrunner housing is a challenge as well, as there is alot more leverage on it that if you would just use it normally, roughly twice it would seem? Just trying to imagine the forces.
Scorpion answered this problem with their press fit endbell bearing. On the large end of the motor, by the mount.
Three bearings to support the diff/endbell. A large bearing on the mount side, one at the center to the shaft, then the last bearing would support the end of the diff.
