crusey_aus
02.25.2010, 05:43 AM
Dont really understand what you are trying to achieve
Do you want an esc that is smaller in physical size ?
Micro pro esc has less power handling capabilities than the stock traxxas esc
Changing the esc will not change the speed of the car assuming they can handle the current demands of the motor
Mamba Max with the Neu on 2s should be fine, change the gearing for more torque and less top end if need be
Cheers
