02.26.2010, 12:12 AM
Does anyone have a slipperential that they can get the bearing to bearing measurement off of? Need to start placement and relationship of the motor and mounts.
Well, if you can follow my logic here: My spider diff is 34mm outside of bearing to outside of bearing. When shifted to the motor side of Mike's cd/motor mount the non-diff side bearing hangs on by 2-3mm. PinkPanda's slipperential just falls out of the non-diff side.
In conclusion, the slipperential must be 2-3mm shorter than an ofna spider diff. I'd say there is 4-5mm more for me to shim in the cd/motor mount, which makes Mike's universal mount about 38-39mm apart.
If you went with 34mm you could just shim any slop from the slipperential.
I hope that is close enough to get you started?
