Havoc
Smokless Nitro
Havoc's Avatar
03.01.2010, 06:30 PM
Originally Posted by swiftneed View Post
Hey guys I just purchased the xt8 conversion and also purchased a new xt8 so I can have everything I need to do the conversion, In this new run of the conversion is there anything I need to look out for
The conversion is a tight fit, due to the narrow chassis design and large battery tray. The mud guards may slightly touch the battery trey and diff spacer, but its perfectly normal.
The chassis comes pre-drilled for the CC Mamba Monster ESC and Tekin RX8. You have to purchase the eRevo mount to utilize this option for the Monster. I originally had mine mounted this way, but I found it easier to velcro and face the servo connecting wire and battery connector towards the battery tray. This gave me a little extra wire on both connectors to reach the receiver and battery.
As jhautz had said:
"Mike should have included a couple 3mm flat nuts in the package. take one of those nuts and thread it all the way onto the threads of the ball stud so its up against the flange on the ball stud. Then when you put the stud through the servo saver arm it will fill the gap that was intended for the nut when the linkage is installed on the bottom of the arm."
I went ahead and used a 3mm nut (w/loctite) on the bottom of the ball stud as well and threw the stock nut in the spare parts drawer.
The battery tray is very long, my hyperion 4S batteries have around an inch or so of space on each end if secured in the middle. I have learned on other cars that no matter how tight you make the straps, the battery is going to slide. I went ahead and put a velcro strip down in the bottom of the tray so I can mount my battery anyway I want. I can have it all the way forward, back, or in the middle with this method. Along with the included straps, the battery isn't going anywhere.
All the other issues I worked out with Mike have been corrected for the later kits.
I took mine to the track yesterday and had a blast. All the problems I had were related to the trucks previous owner and I corrected most of them at the track.
Let me know if you have any other questions.
