t-maxxracer32
t-maxxracer32's Avatar
03.02.2010, 06:35 PM
Your website neeeds more pictures of actual 360s- remember, sex sells, so sexy 360s and cutaway pictures with details of what you are able to fix ( bullet points and lines basically ) would be cool.
I cant figure out how to put pictures that can be viewed without clicking on links.. go to my "home" on my website and you will see the link that i have provided and it will take you to my logo. I tried adding the picture with htlm coding, img coding, direct link, etc but nothing seems to make the picture come up without having to click on a link
maybe you know how to do this?
But yes.. you are right! i need more pics and info.
Krylon fusion on the controllers? Hope so as regular paint will not stick without some sort of adhesion promoter. I would use bulldog adhesion promoter and the krylon fusion. And wipe them down really good with some alcohol/prepsol.
For 40 bucks I might send you mine, and it still works.
I actually airbrush all controllers.. so the paint sticks hella good.
Then i clear coat it with krylon fusion clear coat..
A freind of mine had told me the same thing about how i should use some type of adhesion promoter so i will look more into it.
If you would like me to mod your controller hit me up and lemme know what all you want done!
Originally Posted by scarletboa View Post
only $40 for a rrod fix? my xbox has the rrod and it's still under warranty, but i would rather get a permanent fix and send it to you. let me know when you get that machine dialed in.
just a quick question:
my xbox has the e74 error. you can fix that right? i was told it isn't the typical rrod.
Well if you think about it.. you pay about 12 for shipping to me then 12 for shipping back. Also if i need more parts to fix it the prices will adjust accordingly.. but generally no other parts will be needed.
what do you think a good price would be for me to charge?
In the past I have fixed almost every issue with the 2 methods I used.. reflowing the board and the xclamp fix..
so yes, my methods shouldd fix the e74 problem.
