Originally Posted by crazyjr
Looks good. I hope you got a motor that will pull the wide second gear, because it will be high geared. In that instence i would've used the close ratio. Good luck
Actually, in second gear with the wide ratio set, the revo tranny ratio is 2:111 (38T/18T). The e-maxx in second gear is only 1.722 (31T/18T). The ratio for the revo standard ratio set is 2.29 in second gear - so it's even less.
Emaxx: 2.846 diff x 1.722 tranny (gear 2) x 51T/14T spur/pinion = 17.852958:1 total reduction ratio.
Revo: 2.846 diff x 2.111 tranny (gear 2, wide) x 40T/14T spur/pinion = 17.16544:1 total reduction ratio.
