JThiessen
JThiessen's Avatar
03.09.2010, 10:39 PM
Originally Posted by Gee View Post
Jeff, I found your address and almost put it in the mail yesteday but thought I better make sure you haven't changed addresses in the last year and a half. It's out in the truck but I think it was 1100 something. If nothings changed I will send it out to you.
I won the auction for the chassis - 10 bucks shipped.
So I'm kinda rethinking my overall goal here. I started looking at the possibility of somehow incoroporating a tranny below the chassis (between it and the bottom plate). Wouldnt really be all that tough to do - just a couple of bearing mounts and shaft holes. Just have to figure out how to make it accessible if needed, and close it off from debris. But then I started wondering if there would be more value in designing something more mainstream (ie., a chassis and diff, or a chassis/BrandXX tranny) that I could then possibly give to Mike to add to his conversion list. I personnally have zero interest in producing items for others (its a hobby, not a job), so giving it to him to produce would be in everyones best interest.
What kind of thoughts do you guys have on this? The Dude mount kinda takes care of a standard LST tranny. But, one advantage of possibly going with some other tranny is a significant weight reduction - that LST tranny is one hefty beast. The Revo/3905 tranny would be a fairly easy config, and they are readily available. A Savage tranny would probably fit fairly well also. The Revo would be even better if FLM would make a plate for it like they do for the single speed conversion on the 3906 tranny (nothing but wasted space in it in a single speed config).
This could be a "kit" kinda like the CRT conversion kits.....
